#1 | |
Liked 1,434 Times in 299 Posts
James Schaechter 3163 STK |
#2 | |
Liked 184 Times in 113 Posts
Just do not see it much at the tracks. Then Forced to run the Leaded. |
Liked 1,934 Times in 581 Posts
I prefer VP fuel and have a distributor close to me. I purchase my fuel there and carry enough with me for the race. Typically I carry about 15 gallons along with me. In the past I have had difficulties with the Sunoco fuel and fuel check so I went back to VP. Very rarely do I have any issues with fuel check using VP C12. If you mix the fuel you will have problems at fuel check. Sometimes if you change fuel and don't get all of it out of the system before the new fuel is put in it can cause it to fail. Best is to pick one type of fuel and have enough on hand so you don't have to go through those gyrations.
Mike Pearson 2485 SS |
Liked 998 Times in 276 Posts
If you want to run an approved fuel that's not readily available, you will need to bring an ample supply with you. Changing fuels at the track will require pumping out old fuel, flushing with your new fuel, and I usually have the fuel tested before I go to the lanes to be sure I will pass.
Duane Hoven 1342 SS/GT |
Liked 477 Times in 117 Posts
Careful transporting fuel ... I believe over 15 gallons (inc fuel cell) requires DOT placard and DOT rules ...
Jack McCarthy 3609 STK "the Captain" |
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526 |
#9 | |
Liked 50 Times in 23 Posts
Here you go Dan , pick it up or have it shipped,, cheap enough !! https://petroleumservicecompany.com/...4-gallon-drum/
Steve Stickel 1161 Stk 1167 SS |
#10 | |
Liked 62 Times in 29 Posts
I picked up two 55 gallon drums of fuel a few months ago for some friends. I was told this was totally legal, AND, I could have taken two more drum of Alky to go along with that race fuel since they have different numbers on the tag indicating what was in the drum. I was told there is a weight limit, not a gallon limit. Also was told I could legally transport up to 900 pounds of radioactive materials without a permit........... But like most things, when the State and Federal Government gets involved, things get messed-up! Some states require a CDL for our tow rigs, others don't. Would be nice to have common laws across the country, but that will never happen. |
