Old 12-04-2019, 03:00 PM   #1
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Mopar bogus intake removed
Finally
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 12-04-2019, 05:47 PM   #2
Billy Nees
Liked 7,783 Times in 1,743 Posts
Default Re: Mopar bogus intake removed
Hurray!!! Hey NHRA, now how about going after some FFFord and Chevy intakes!
Billy Nees 1188 STK, SS
Old 12-05-2019, 09:06 PM   #3
James L Miller
Liked 25 Times in 16 Posts
I have two. The new head face angle rule probably will make other parts illegal too! I guess I need to get a car built before everything is made illegal. No wonder most people think I'm nuts for wanting to run Stock or SS.
Mopar 2 Ya!
Old 12-06-2019, 08:03 AM   #4
thekidd
Liked 4 Times in 2 Posts
james I got a super stocker ill sell you way cheaper than you can build one
thekidd is offline   Reply With Quote
Old 12-06-2019, 08:14 AM   #5
jmcarter
jmcarter's Avatar
It’s a deal too...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-06-2019, 09:43 AM   #6
Jeff Stout
Liked 704 Times in 281 Posts
What's all the fuss about? This intake was with nothing in ET. So im told. LOL
Jeff Stout is online now   Reply With Quote
Old 12-06-2019, 03:55 PM   #7
Greg Marshall
Greg Marshall's Avatar
Liked 10 Times in 6 Posts
About time, i was in a heads up race and on a second under pass and lifted after seeing just tail lights of the 65 Valiant I looked at their car's incrementals and it was on a 1.30 under pass
NHRA Tech Department makes changes to the engine blue print specifications
Dec. 4, 2019
The NHRA Technical Department recently made changes to the blueprint specifications.
This change is in regards to the use of the Mopar Performance 2836139 (LD-4B) intake manifold for the 1965 thru 1967 Mopar Stock engines. On December 4th, 2019 the NHRA Tech Dept. deleted this part from the Blueprint specs. This was done following extensive research and review of our files from the manufacturer. This part was not an OEM part and was a dealer replacement. Per the NHRA rule book equipment other than factory installed is prohibited. On January 1st, 2020 this part will no longer be permitted.
Greg Marshall is offline   Reply With Quote
Old 12-06-2019, 07:23 PM   #8
Rod Greene
Liked 242 Times in 81 Posts
It is amazing the celebrating that goes on here against the Mopar contigent. What is there maybe 3 or 4 cars that had that manifold? Lots of bogus Chebies and Phords. The car I am familiar with that had the LD340 manifold went just a quick without it at INDY.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 12-06-2019, 07:27 PM   #9
Rod Greene
It is amazing the celebrating that goes on here against the Mopar contigent. What is there maybe 3 or 4 cars that had that manifold? Lots of bogus Chebies and Phords. The car I am familiar with that had the LD340 manifold went just a quick without it at INDY. Just like happened with the AMC stuff how many racers are you going to lose. I remember when the phords got bigger cams and manifolds and carbs where was the protest then? 327 intakes on 283 chebies?
Old 12-06-2019, 08:02 PM   #10
Rb105
Cry baby’s
Rb105 is offline   Reply With Quote
