Old 12-09-2019, 09:06 PM   #1
Default Re: NHRA 2020 Rule Amendment SS Intakes???
Originally Posted by Crew Chief View Post
As it was just explained to me, the new rule applies to those who have an angled spacer plate being used to replace material that has been cut off at an angle on the intake side of the head. They will also be looking for the OEM angle between the intake side of the head and the block side of the head. That is what the +/- 2 degree allowance is about.
Okay... I haven't seen the rule, as written, but I don't see the problem then.
Everyone knows what the intake face angle should be on all the popular combinations.
That angle should be what's allowed. That, and the v.c. bolt hole limit.
The spacers shouldn't have anything to do with this.
Someone could change the head angle, then build a custom manifold to match it, if it were allowed.
Also, I believe some of the spacers would have to use countersunk bolts into the head, and then they would be covered up by the manifold pattern. So, no, you couldn't just weld the spacers to the manifold.
*Edit : I just read post # 12. I assume this was lifted from the new rule book.. Is this under intakes or heads?
This , too me , looks like NO adapters at all, in S/S.
I guess the saving grace here is that not too much of y'all's money could be going to their lawyers. What a bunch of contradictory gibberish.
Old 12-12-2019, 02:14 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I didn't realize sheet metal intakes were allowed in SS. SS and GT mention "any manifold..." but "sheet metal allowed" isn't mentioned until the Modified section. Modified cars have one foot in Comp and one in SS.
Dale Shearon
68 Mustang 6394
