Old 12-13-2019, 12:29 AM   #1
cmracing
Liked 62 Times in 29 Posts
Default Re: How Much Does Density Altitude Affect ET
Originally Posted by Keith 944 View Post
On my two cars basically 200 feet of altitude change equals one hundred .01 I run them a little fat so that it will be this way
My faster car is about .01 per 300ft running on race gas.
cmracing is offline   Reply With Quote
Old 12-13-2019, 10:19 AM   #2
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
My experience has been that if you run around the ideal air/fuel ratio you will see 150 ft equals .01. Or you can run lean and move higher into the 200ft area. It gets hairy as you get leaner and can do engine damage. The only time that I've seen the 300ft range is with ethanol in our bracket car. A normal ethanol car will equal the 300ft per .01 area. If you don't see these numbers or if your car isn't consistent , you probably have a problem that needs correcting.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
