Old 12-27-2019, 09:52 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default Re: Rear Gears
if you are so determined to find GL-6 rated lubes do a little internet research they have not made it for years but some of the lubes are rated as Gl-6 the equipment that can test GL-6 is not even made or in service anymore-- several companies offer GL-6 rated lubes -- it is not the end all cure all of gear problems especially if your are looking for a TENTH or do not want to do maintenance or have wanted 500 run ever lasting ring & pinions -- it is merely quite possibly a performance enhancer but its lube and its not going to guarantee you are going to win races--do some research its not the magic potion everybody is looking for but it can maybe keep you stuff together longer--FED 387
Old 01-02-2020, 10:48 PM   #2
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
We use Motive performance gears Ford 9" going 4.80-90's 142 in Florida on 275 radials 2900 3000 pds, one teen sixty foot. It's not a pro gear, not a street gear either, but a performance gear. I have one in my Nova as well, N/A sbc 3200 pds 1.27 60ft 10 x 28. For a future option for consideration, we've been impressed with them so far. Reasonably priced as well.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 01-04-2020, 07:48 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
Mike, I have a set of 9' ford 6.33 from them that have lasted. Most guys using 6.33 don't get good life from them. Small pinion tooth count is murder. IMHO Motive Gear has pretty good products.
Adger Smith (Former SS)
