Old 12-28-2019, 11:09 AM   #11
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Several years back Gary & Ann Moore had some good running Pontiac Stock & Super Stock cars in Div 4.
The only Gary Moore I've ever heard of was on the "I've Got a Secret" TV show, many moons ago.
But, div 4 is my div. So, I am real interested in learning all I can about their Pontiacs. So, anybody with info/pics, please post.
That jogged my memory. Back when I had my Stockers, local tracks quit running class, & switched to brackets. But, one track kept a class they called Street Modified. A small cube Super Stock car would have worked good in that class. It was just a lbs per cubic inch class, using NHRA legal weights. Roller cams, Holley carbs, big tires, & ladder bars were legal.
It was a class designed for high rpm small cube engines. I had no chance, with a Pontiac engine. But, I couldn't run in Stock any more, so I decided to give it a try. Big mistake. I found a cheap(they were all cheap back then) '68 Bird 'vert & Put some roll bars in it. Got the 'vert because it could run at a heavier weight.
Anyhow, my engine builder, in Shreveport, did the machine work on lots of race stuff, including one SS Pontiac. He contacted the Pontiac guy, & got me one of his old solid roller cams. But, some new guys opened a machine shop in a small town, only about 30 miles from me. Their head guy was from CA, and supposedly had lots of experience. Hey, they even had a TF dragster.
So, I figured they knew what they were doing. WRONG ! They didn't know anything about Pontiac engines. I got it running, then had to take it back for new oil rings, and a sleeve, before even taking it to the track.
Anyhow, I finally got it to the track. Hey it SOUNDED good. It was my first roller cam engine. Of course it wasn't near quick enuff to run with the sbc engines, in the lbs per cubic inch class. It wasn't bracket racing. 1st car to the finish line won.
It did run quicker than our Stockers, but not competitive in that class. But we did make a couple of races, & TJ got to make a lot of noise & go quicker than she'd gone in the Stocker. Then "boom". Rod out the side. Discovered that it was the machine shop's fault. I think they only lasted one year. Must have messed up some other stuff too.
Hey, I won't charge ya'll anything for that little bit of Pontiac racing history !
