Old 12-29-2019, 08:20 PM   #1
bykr
Liked 167 Times in 81 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
Originally Posted by Mike Gray View Post
It was never built for SS, I suppose you have first hand knowledge why it’s “junk”?
I do, I owned one. The Cleveland intake that it attaches to has runners that aren't nearly as long as the FE so the adapter has to make some fairly abrupt bends on the end cylinders. Fast guys were taking a Ford tunnelwedge 2-4bbl. intake and making a 1-4bbl.intake out of it like Holbrook, but $$. The Edelbrock Victor for the FE pretty much killed any thought of this adapter being used.
bykr is offline   Reply With Quote
Old 12-29-2019, 10:34 PM   #2
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Welp, looks like 2020 will be the final year for us!
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 12-29-2019, 11:28 PM   #3
bykr
Correct me if I'm wrong but if you angle mill the head at an extreme angle thereby reducing the port volume and NHRA only measures the head port volume aren't these "spacers" allowing larger cylinder head port volumes? It's not really about adapting different intakes but using the "spacer" to raise cylinder head port volume as the head isn't measured with the spacer installed. I guess the port entry can be raised also. Seems like a reasonable rule change to me. Although I feel for those affected, anytime you push the rules you put yourself in a position to have the rules get tightened, not in you favor whether it's been accepted before or not.
Old 12-30-2019, 12:39 AM   #4
SSDiv6
The volumes are measured without the adapters.
Old 12-30-2019, 12:42 AM   #5
Thanks , Joe
(123 posts later ;-) )
Old 12-30-2019, 02:10 AM   #6
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
I wonder if exhaust adaptors will be illegal too? I mean, the angle should be checked on the exhaust side, if the intake rule gets reinstated!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 12-31-2019, 02:32 PM   #7
Tom Broome
Liked 88 Times in 43 Posts
I got that t-shirt the first year NHRA started checking port volume. Milled the exhaust surface almost smooth on some SB Chev heads.....Tech didn't want to see them again.
Want to discuss chamber mods and angle milling?
Tom Broome is offline   Reply With Quote
Old 12-30-2019, 02:14 AM   #8
bykr
That's my point. If you mill the head at a severe angle won't the cc's of the cylinder head runner be reduced? You can then open the runner up in other areas to bring the head back spec. cc's. The whole point of doing it.
Old 12-30-2019, 09:28 AM   #9
Bobby DiDomenico
Liked 101 Times in 52 Posts
That's what I thought. Besides a better intake you're gaining CC's to work with and possibly changing the entry angle somewhat.
Old 12-30-2019, 05:07 PM   #10
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
I don't understand the problem if porting, polishing, welding and epoxying is already permitted?
From rule book SS heads -
Must be correct casting number for year and horsepower claimed, per NHRA Technical Bulletins or NHRA-accepted. Cylinder-head casting must also be on NHRA runner volume list as published on NHRARacer.com. Porting, polishing, welding, epoxying, and acid-porting permitted.
