Old 03-08-2008, 06:27 PM   #1
j gardiner
Liked 55 Times in 29 Posts
Default Re: 2-step buttons again
this is the point i was getting at when i started this post, was that there must be a better way of using the 2-step button. the way thet have written this new rule doesn't give you much to work with. they did not think about this to much when they made this rule. the only reason this was done was to try to mess with some of the hitters and take them out of there game, now they have some half *** rule that is potentially dangerous and shame on ihra for following nhra's lead on this crap. my .02
j gardiner is offline   Reply With Quote
Old 03-08-2008, 07:39 PM   #2
art leong
One question?????
In superstock can the two step and the trans brake be on the same switch?
Art Leong 2095 SS
Old 03-08-2008, 07:56 PM   #3
Todd Hoven
Guest
Posts: n/a
Originally Posted by art leong View Post
One question?????
Of course, how would you run it? The only reason people cant run it in stock on a seperate button is because of all the people that bitched about it. Super stock rule is unchanged on that.
Old 03-08-2008, 07:59 PM   #4
Todd Hoven
Guest
Posts: n/a
Andy, people voted on it and they just passed a new rule, why would they change it a month later? Do you think people feel different now? Did anybody buy the 1978 Sports Nats Video? None of the stick cars had a 2 step there? Whay do they need them now? Reason because it helps and makes it easier to race? The same reason why auto guys like running it.
Originally Posted by Stick Racing View Post
Here's an idea: How about banning 2-steps in stock?
I fail to see the reason anyone needs a 2-step with an automatic. If you like buttons, get a super class car.
I'm looking forward to the new advisory council putting an end to these thoughtless rules.
Andy Stone 1102 B/S
Old 03-08-2008, 08:59 PM   #5
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Angry Re: 2-step buttons again
I wonder how many people have their lawyer on retainer for when the guy in the other lane hits the brakes at the stripe,activating the 2 step, and he loses it at contact is made.I never liked the idea of 2 steps in Stock and with the new rule now I'm also a bit leary about the above senario.
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-08-2008, 09:55 PM   #6
Stick Racing
Todd, yes it was voted on. However, IMO, an accurate vote should consist of a much broader system than just the racers with a computer and knowledge that the subject was actually up for vote.
Why would they change it a month later? They changed the ruling on blinders from nothing to something stationary. Maybe it was easy to change that rule because that one wasn't 'voted' on?
Reason because it helps and makes it easier to race? Easy? Gee, I guess that's what sets me apart.
I want to be in control of the car. I want the challange.I cut my teeth here: www.prostickracing.com.
78 Sports Nats. None of the stick cars had a 2-step there? Wish I was there!
The 2 step rule I can live with. The 2 step switch on the brake pedal is an accident waiting to happen.
Prime example of a rule implimented before going through the thought process.
Andy Stone 1102 B/S
Stick Racing is offline   Reply With Quote
Old 03-08-2008, 10:23 PM   #7
Todd Hoven
Guest
Posts: n/a
Wink Re: 2-step buttons again
Ed, I heard of guys using the 2 step to kill ET on the top end. I know of guys that have used it on the pedal for years and have had no problem. It isn't like throwing the car in reverse at 120 MPH. I would not loose sleep over it.
I am reverseing my posistion here but the stick guys should be alowed to use a remote button to activate the 2 step to make it easier to wire the car and shift it with out the 2 step coming on. I wouldn't mind that rule changing for those guys.
Just can't wait for the season to start up here.
Ed F.
Old 03-08-2008, 10:55 PM   #8
Todd Hoven
Guest
Posts: n/a
http://www.prostickracing.com/
Hey Andy, that is a kick *** website. Are you coming to Atco this April?
Old 03-08-2008, 11:15 PM   #9
Liked 1,853 Times in 419 Posts
Originally Posted by 1664SSJA View Post
Alan,
Am I correct in the way I explained wiring it though? If so, the wires from BOTH buttons could be TOTALLY exposed and an easy look to see that they go the the terminals on the MSD box.
If this is correct, its beyond me why they would not allow this for both safety and ease of use concerns. They are worrying about blinders being a safety issue, and here you have guys flipping switches everywhere on the track....
If how I explained wiring it would not work, let me know.
Otherwise, I dont see how they would say no..... if they see a wire ( and it would be very easy to see) going from linelock up and under the dash somewhere..... well there you have it. If someone wanted to tie into the linelock it can still be done now, with their rules without them seeing it without following the wire out to the solenoid.
My thinking is that this would all be exposed and very easy for them to check without stepping into the car....am I wrong?
Seems like the way they allow it to be NOW, would give more of a chance to hide stuff with all the wiring and switches that are being mentioned. Further down a guy mentions how he does it and is using two toggles..... one for the burnout, and then another he turns on I think he said....after the burnout, but then has to turn OFF going down the track.
Another very good option to the guys they think may want to hide boxes, is that you do not even get a second chance. If a hidden delay device is found, your out and can't come back. Period.
Mark
Mark,
All I can tell you is that I asked several very specific questions of a couple of NHRA tech people, and was told the same thing. The rule, as currently written, allows for ONE switch, ONLY, mounted on, or activated by, either the clutch pedal on a stick car, or the brake pedal on an automatic car. I wanted to put a switch on the car to disable the two step if the car was not in 1st gear. There was no way to do it under the current rule. I think the rule is wrong, but it is the rule.
