Old 01-19-2020, 01:58 PM   #1
jmoneyfoot
Liked 9 Times in 5 Posts
Default Amsoil engine oil
Does anyone here run amsoil in their stock/superstocker? What weight? I picked up a sponsor from a small amsoil rep and he wants me to try some. I have never used any amsoil products so any info would be great, thank you
jmoneyfoot is offline   Reply With Quote
Old 01-19-2020, 03:36 PM   #2
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Default Re: Amzoil engine oil
Originally Posted by jmoneyfoot View Post
Does anyone here run amzoil in their stock/superstocker? What weight? I picked up a sponsor from a small amzoil rep and he wants me to try some. I have never used any amzoil products so any info would be great, thank you
I've been having good luck with the Amsoil 10w-30 synthetic Dominator race oil in my Super Stock 427. Other than a rod bearing issue I had last year, which was not due to the oil I am using, the bearings look perfect every time it's apart. I also use their synthetic ATF and gear lube with good results.
Old 01-19-2020, 06:10 PM   #3
340Cuda
Liked 801 Times in 338 Posts
I have never used it but member "Locomotion" has used it for years and should have a meaningful response when he sees this.
Old 01-19-2020, 06:56 PM   #4
killintime6968
Liked 91 Times in 29 Posts
Smile Re: Amzoil engine oil
The first thing about having Amsoil as a sponsor is making sure you spell their name correctly. LOL . That being said I have used their products for years in my Race quads and sleds. Also have used their assembly lube in engines.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 01-19-2020, 07:43 PM   #5
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Amzoil engine oil
Great oil, I use 10w30 in my stocker
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 01-19-2020, 08:19 PM   #6
Jeff Niceswanger
Liked 1,032 Times in 368 Posts
We have ran it for a long time. Actually had the oil pump pick up break off and made entire 7800 rpm dyno pull with 10 psi pressure and the bearings looked new. Yes, the dyno operator was a bit red faced, but it turned out alright. That's what really sold us on it. We use the 10-30 Dominator, but I know some people with tighter bearing clearances than us run the Dominator 20w all the time. I've been told its slower than most oils on the dyno, but if your looking for protection, its a great choice.
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 01-19-2020, 08:51 PM   #7
taylordunahoo
Liked 2 Times in 2 Posts
We started using the 5w-20 Dominator racing oil in our Jr Dragster many years ago and liked it so good we started using it in the super stocker when Taylor started driving it. We turn this thing 8800 RPM in the quarter mile and after 175 runs bearings looked brand new.I didnt even replace them when i freshend the engine last spring. We also run Amsoil ATF and gear oil.
taylordunahoo is offline   Reply With Quote
Old 01-20-2020, 09:38 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
AMSOIL Sponsored The Engine Masters Challenge. Every participant was required to use Amsoil oil. They got to choose which oil and the weight.. all for no charge. I did the tech for 10 years and as far as I could tell there was never an oil related failure. I took apart all the winning engines for inspection and verification. I never saw any damage from oil breakdown. Saw some part failing...but nothing the oil had a hand in. I did see some roller lifters fail from abusive cam profiles. RJ Sledge was the Tech guy in our team that made sure they poured in the AMSOIL and no one sneak anything in other than their oil.. By the rules No additives allowed.
Adger Smith (Former SS)
Old 01-20-2020, 11:30 PM   #9
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Been running 5W20 Dominator for about 4 years with great results. Refresh showed very little wear after over 220 runs in my 360 Stocker. Jim
Old 01-21-2020, 08:23 AM   #10
nhramnl
Liked 358 Times in 83 Posts
Seems kinda sad, but AMZOIL never seems to have been "accepted" by racers. The people that use it seem to swear by it, but the people that don't seem to have nothing good to say. Anybody know of a historical incident or something that gave it a bad rep?
