Old 01-22-2020, 04:34 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Re: Question on loosing fuel pressure going down track.
Have you checked the pressure before the regulator? Most pumps put out about 15 PSI.
You may have a low pressure pump not designed to use with a regulator or the pump is no good.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
