Old 02-14-2020, 05:24 PM   #1
James Perrone
Liked 1,861 Times in 434 Posts
Default Re: 69 camaro rear rim size
Get the hammer or saw out. Shane.
Don’t forget basis ply tire grown. Much more clearance needed
Not like a dragster.
james perrone 1290 STK
Old 02-14-2020, 07:07 PM   #2
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
1/2 may be enough, although it might rub when you turn. Keep in mind if you need to add weight in the trunk it will sit even lower. I actually had to beat in the inner wheel house at the bottom edge. Just need to get creative with a dead blow hammer! A little bit here and there helps.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
