Old 02-17-2020, 02:04 PM   #1
OkieRocket
OkieRocket's Avatar
Liked 6 Times in 5 Posts
Default Strange B3360 Master Cylinder Push Rod
I recently purchased a Strange B3360 Master Cylinder Kit to "retrofit" into my 1970 Olds 442 Drag Car. I am replacing the OEM Cast Iron Manual Disc Brake Master Cylinder. I am finding that the "Push Rod" supplied in the Kit from Strange is approx. 1" - 2" too short. Strange does not offer any optional Push Rods and I can't find anyone in the Parts aftermarket that can tell me which Push Rod to use.
I've seen all kinds of basic "fixes" on the internet in chat rooms, etc., saying to simply.... "Cut" a grade 8 bolt to length and "grind off" the end to a ball".....or just "use some 3/8-24 all-thread rod," etc..... I know you guys in this forum are true, serious Racers that know your stuff and I am afraid of simply "grinding off a bolt" or doing a "cheesy" fix to the issue and want to do this the right way...mainly for safety reasons.
Any recommendations would be greatly appreciated.
Harold
OkieRocket is offline   Reply With Quote
Old 02-17-2020, 03:19 PM   #2
Eman
Liked 133 Times in 76 Posts
Default Re: Strange B3360 Master Cylinder Push Rod
I used a Mopar style MC on my 3rd Gen Camaro. It wasn't bought from Strange but I don't think there is much difference. I had to make a rod to work properly. Jegs sells a rod kit with a clevis that you can make work. They also sell a boot for the rear of the master cyliner where the rod goes to use as a guide. One thing that is very important is to be sure there is no possible way the rod can be pulled out of the rear of the MC and drop. I removed my whole pedal quadrant and mocked it up on the bench. Then I welded in a flat piece of steel with a hole drilled in it as a guide for the rod. Also made sure I had a very positive pedal stop to prevent pulling the pedal back too far. There have been racers that have overlooked these items. Somehow their foot hooked under the pedal and when they pulled it out they dislodged the rod resulting in no brakes.
Old 02-17-2020, 04:02 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Eman has a good suggestion in ref to removing the pedal assemble and getting on the bench where you can fab up as needed to address the potential problems as he explained.
It is a serious safety issue so please be careful.
Larry Woodfin 471W
Old 02-17-2020, 08:34 PM   #4
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
I used an adjustable push rod with that MC
https://www.doctordiff.com/62-70-adj...-push-rod.html
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 02-18-2020, 11:33 AM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 881 Times in 236 Posts
This part from Jerry Bickel Race cars is simple and inexpensive .
I use it on all my builds.
Part number JBRC1064 $69.00
Tom Goldman is online now   Reply With Quote
Old 02-20-2020, 10:03 PM   #6
OkieRocket
OkieRocket's Avatar
Thanks for all of the great ideas guys! I really appreciate the help.
Harold
Old 02-21-2020, 01:57 AM   #7
CMcAllister
Liked 920 Times in 259 Posts
I have made the cup and welded a stop on the pushrod to function like this unit, but for the price and quality of this assembly, it's an easy decision to just use this piece. A positive pedal stop will provide an extra margin of safety.
I've seen a number of cars torn up and people hurt as a result of inattention to this.
Old 02-21-2020, 10:07 AM   #8
Tom Goldman
It's one of the first things I look at when a car comes into the shop for work , especially older race cars .
And its not just Stock /SuperStock cars ,A lot of Bracket and Super class cars are also lacking adequate push rod retention.
Old 02-24-2020, 07:33 PM   #9
OkieRocket
OkieRocket's Avatar
Smile Re: Strange B3360 Master Cylinder Push Rod
Great info. Guys!
Thank you!
Old 02-25-2020, 10:01 AM   #10
Rod Greene
Liked 242 Times in 81 Posts
This is what happens when the pushrod comes out
ID:	53977   Click image for larger version
ID:	53978   Click image for larger version
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
