Old 03-05-2020, 07:23 PM   #27
Ralph A Powell
Liked 225 Times in 136 Posts
Default Re: Problem with lash closing up
Your Lash was off the first time? Maybe you should get your old P&G out and use it!
Originally Posted by ss3011 View Post
Probably should have said right from the start that this is a stocker engine with a flat tappet cam . Today we pulled the intake and examined each lifter and cam lobes . This is the second year on these parts and they still look brand new . It has cast iron heads , and the valve seats are not replaced , they are just machined into the casting . This year the valve job still looked OK so the valves were lapped and re-installed . Springs were not replaced and are still at 200 on the seat just like when it was reassembled . Engine has about 10 pulls since re-assembled . These are good parts , Trend lifters DLC coated , Steel cam , PAC springs .
The next step I think will be to try and measure the length of each valve , and see if Cylinder 4 valves are .003 longer than the others . I would think when the original valve job was done , all the valve lengths should have been ground to the identical length .
Thanks for all the ideas , it helps .
