#11 |
Liked 2,343 Times in 465 Posts
#12 |
Liked 269 Times in 99 Posts
What you may consider is isolating the camshaft by forming a closed tunnel with oil return run directly down to the pan. Cam, lifters and bearings see plenty of oil maybe too much but would not fall into windage with an internal or external oil return line or limit the fall to the rear only for not 100% effect.
When looking at this a few years ago it's difficult with SBC without a lot of work I spent hours cutting and filing PVC tube to fit planning to pin and epoxy but issues with connecting rod clearance made it too much work at that time and became evident sheet metal would have been a better choice. When searching cases where I could see this actually done this was with a Ford with dry sump much easier to control putting oil in the front and return in the back the tunnel would be filled or nearly. Great idea to apply to a stocker there would be HP there but the labor cost would be more than most would pay but a crafty guy doing it for himself............
#13 |
Liked 100 Times in 51 Posts
A very good friend of mine that knows a few things about engine building and find HP told me that when the engine is running, the camshaft is spinning on a film of oil. It isn't dragging against the bearing material.
Dan
Dan Foley SC 4698 |
#15 | |
Liked 18 Times in 10 Posts
It takes more power to move all those needle bearings VS the cam sliding on a film of oil. I blue print bore a lot of blocks for 55MM cam journals for other shops and builders babbit seems like the way to go. Also machine some of the OEM 350 blocks to 2.120 and use the GMP-1 cam bearings for BBC journals. |
#16 | |
Liked 373 Times in 129 Posts
Carl Some years back I had a contract to build Winston West 9.1 comp 390 carbed 358 engines. We were quite sucessful and won several races, every engine we built had roller cam bearings, but also were dry sump. I never saw any weird stuff going on in those engines, they made right at 600 HP. Not going to say there was no harmonics, but we never had problems. We also built some with 55 MM babbit, I never saw any difference on the dyno, I did like getting rid of the oil leaks. Last edited by HP HUNTER; 05-21-2020 at 10:30 PM. |
#17 |
Liked 70 Times in 22 Posts
Anyone have any experience with roller cam bearings on the street. I have 2 Gen3 hemi aluminum blocks that have been cut for 60mm roller bearings. These are in a cam tunnel so no oil from the top and I don't know if you could put a hole in the bearing cage for oil without hurting the bearing. These are destroked and bored to 305" and Bryant cranks and blocks are cut for LS chevy bearings to get a full thrust bearing for road racing. I was thinking of 1 for a street rod but not sure the bearings would oil enough at low RPM on the street. Any thoughts?
Stewart Way 2424 SS |
#18 | |
Liked 974 Times in 310 Posts
#19 | |
#20 |
Liked 783 Times in 195 Posts
Isky "Imperial" camshafts.
