Old 06-23-2020, 07:35 AM   #11
Liked 10,756 Times in 2,236 Posts
Default Re: Trans Problems!
Do the water box stuff in second, it keeps wheel speed down and doesn't abrad away the center of the tread. Transmissions and tires will last longer.
Old 06-23-2020, 09:31 AM   #12
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
Do NOT end your burnout in second gear, if it hooks at the end of the burnout in second gear, it's almost guaranteed to roll the sprague. Always finish your burnout in high gear.
NHRA1926 is offline   Reply With Quote
Old 06-23-2020, 10:07 AM   #13
BZenzen
BZenzen's Avatar
Liked 472 Times in 82 Posts
We always do the burnout 2-3, but we've always hit neutral at the finish line and shut it off.
We did that for years with our Glide, but now the TH350 can't handle it I am guessing. Thanks for the input guys
Brian Zenzen
SS 5404
STK 5401
BZenzen is offline   Reply With Quote
Old 06-23-2020, 10:25 AM   #14
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
I've been doing high gear only burnouts with glides and 3 speeds (T400, T350, and T200) for years. Currently have a T350 in my Super Stocker. Never have had an issue with any trans that was burnout related. I was told years ago by a reputable trans builder that one of the hardest things on a trans is shifting in the burnout. As long as you have some dampness on the tires, there is no need to be in a lower gear for the burnout.
I too neutral the car after the finish line. My current trans builder hasn't yelled at me yet for doing so... :-)
Old 06-23-2020, 12:07 PM   #15
Greg West
Liked 52 Times in 22 Posts
Although there are pros & cons about not backing down the engine in gear at the end of a run, many other forms of racing do it all the time. Circle track, road racing, etc.do it. Is it really such a bad thing to do? Martinsville would be a good example of this occurring lap after lap.
Greg West is offline   Reply With Quote
Old 06-23-2020, 12:15 PM   #16
Jeff Stout
Liked 704 Times in 281 Posts
Did burnout for many years in second and shift to third. Then with in 1 year I broke a sprag twice on T400. Started burnout in high only and never broke one again. Strange how it went from no problem to a problem.
Old 06-23-2020, 06:47 PM   #17
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Nice to hear that transmissions other than a Chrysler 727 can have sprag issues.
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 06-24-2020, 02:11 PM   #18
rx dealer
Liked 53 Times in 13 Posts
Check PM
rx dealer is offline   Reply With Quote
Old 06-27-2020, 04:05 PM   #19
Ed Wright
Ed Wright's Avatar
And, my Pro Trans (T350) has the “Clean Neutral” option. Shift to Neutral at the finish line, with no issues.
Ed Wright 4156 SS/JA
