Liked 165 Times in 59 Posts
.003-.004 lash is tight ,need to be more like .007-.010 ,,also mesuring Pinon depth by the numbers will get you close but the tooth pattern and the feel is the final way to go at it ,I have a few sets of ratios I swap and use a slip fit pinion bearing rather than the shim behind the pinion race
