Liked 138 Times in 51 Posts
If you're still wanting to try the 12 bolt, perhaps Charlie Boyles could offer some advice and what to expect with a 12 bolt.
http://www.competitionplus.com/drag-...a-legend-lives
LOCOMOTION Racing |
Liked 783 Times in 195 Posts
Hypoid angle for a Dana 60 is less than a 12 bolt. Several years ago, Car Craft did a side-by-side comparison of a 12-bolt, a Dana 60 and a 9-inch. The 9-inch was the loser. No clear winner between the 12-bolt and the Dana.
Liked 354 Times in 120 Posts
I have run a 12 bolt in my Chevy II forever, steel spool reg axles 6.14 gear. 283 SS car with brake 6000 + . Used good gear oil and had very few problems putting hundreds of runs on the gears. Only if I was looking for saving weight would I switch. There is a difference in sprung and unsprung weight that may pick the car up. Unless you get the 12 bolt stuff cheep money might be better on other go fast parts. Way back in the day Rick Johnson ran a 12 bolt in his hemi car. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 07-28-2020 at 08:54 PM. |
#4 | |
Liked 19 Times in 17 Posts
Liked 888 Times in 239 Posts
Since I have parts for both 12 bolt and Dana 60 in the shop right now ,I decided it was time to weigh in ,literally by putting everything on the scale.
Both rears measured within an inch of each other ,12 bolt 53" ,Dana 54" both have 1/4" chrome moly tubes and 3.15"bearing ends, both have steel caps. Dana 60 90 pounds , 12 bolt GM 70 pounds Both have Strange light weight steel spools Dana 60 13 pounds 12 bolt GM 8 pounds Both have standard non lightened gears Dana 60 16 1/2 pounds 12 bolt GM 14 pounds Axles and bearings and yokes are within ounces So the total unsprung weight difference is 27 1/2 pounds and rotating weight difference is 7 1/5 pounds. The Dana still is better for frictional loss efficiency than the 12 bolt but that surely is offset by the difference in rotating mass. Bottom line is both have their strengths and weaknesses . Ratio choice is much better for the 12 bolt for sure , and if we are talking a Stocker ,well you know what you have to do .
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 07-30-2020 at 11:18 AM. |
Liked 127 Times in 26 Posts
Question, what does a COPO, Cobra Jet and Drag Pack cars have for rear ends and what gear ratio and tire size? Thanks
Liked 227 Times in 138 Posts
9 inch Fords in Chevy new Mopar and Fords
