#11 |
Liked 880 Times in 311 Posts
IMHO the gear sets need more backlash, AKA Space, for the gear lube to build a film for the gears to mesh on. I'm thinking the .008+ Up^.. If the pattern doesn't look right you can usually adjust the pinion depth to get the pattern right at that backlash. Some where I have a 1962 Motor Manual that explains the back lash pinion moves vs pattern location.
Adger Smith (Former SS) Last edited by Adger Smith; 07-22-2020 at 07:57 AM. Reason: add |
#12 |
Liked 240 Times in 112 Posts
.003 - .004 seems kinda tight to me.
Dave Noll, EF/S ,?/SA 6526 |
#13 |
Liked 126 Times in 61 Posts
Needs to be .010 to .012
#14 |
Liked 49 Times in 22 Posts
I switch to US gear, and like them, the old Richmond gears the double diamond are good, but i think they have had multiple buy outs over the years, and quality is not the same.
Steven Barnes Stock 704 N/SA |
#15 |
Liked 80 Times in 28 Posts
John, I run same car, but a lot less torque (340) with 8.75 ,point is we always have the gears heat treated. Have had very few problems, even running close to 3700 lbs. We do run 6-12 thou. bk-lash, with auto trans. good luck. Glen H 1257
#16 |
There was some positive reviews about Motive Gears that are manufactured in Italy.
#17 |
Liked 2,487 Times in 698 Posts
Thanks.............Appreciate the help!
#18 |
Liked 129 Times in 35 Posts
john don't complain about 200-220 check them real good at 100 replace at 160-175 never in 50 years have we got 200 out of dana gears we have 5.13 in our satellite with 2.94 low gear set so could make a difference and chads car also pretty heavy in C/SA this is my 2 cents
#20 |
Liked 10,759 Times in 2,236 Posts
In the A B C six pack car we got over 15 years of service from a pro gear Dana. 3700# in C to 3200# in A
