Liked 227 Times in 74 Posts
Powerglide 1.76 gear, Reid case has expired. Turbo spline input. Built by Hughes with there parts and Brake $1700
Powerglide 1.80 straight cut gear, Reid case has expired. Turbo spline input. Hipster valve body and brake. After a rebuild had to stage with higher rpm then idle. Is missing a check ball when put back together. $1700 Powerglide 1.76 gear, stock case. Turbo spline input. Built by Hughes, Hughes valve body and brake. $900 Have 2 stock powerglides one 8cyl, 6cyl $ 50 each Have a stock PG case $25 Brand New Reid 2 piece case with chevy bellhousing but has expired $500 SOLD Reid case slighty used great shape, expired $500 Hughes Converter BS9D 1.125 $400 Have Pictures I can text, for more info PM me, will be in Boise All this was behind S/G S/ST car with BBC
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 Last edited by west coast; 08-18-2020 at 09:04 AM. |
#2 | |
Liked 359 Times in 103 Posts
Thanks Rick Cates Canyon, TX |
Liked 52 Times in 5 Posts
PM sent. . . . thank you.
