Liked 205 Times in 93 Posts
thankyou everyone for your help! ive have the fluid level to the dipstick full mark, WITH the deep pan on...did not remark the full mark...2 3/4" deep pan.
Liked 71 Times in 38 Posts
Fluid level cold should be at “add 1 pint” ATF will expand as it heats up.
1 1/2" ...full mark to dipstick end.
Are you using the oem dipstick and tube or an aftermarket ? Even with a deep pan I believe the fluid level should be below the pan rail. If it’s an aftermarket dipstick try draining the pan so the oil level shows about 1/4 up the dipstick cold. Then go for a test drive heat cycle the trans and recheck to see if the oil level is at full when hot.
we originally had a fancy milodon unit. i thought it was the leak source, went back to the factory piece. will get it sorted out and go back to fancy...
Liked 880 Times in 311 Posts
You just need Flex Seal
Adger Smith (Former SS) |
