Old 08-14-2020, 12:09 PM   #1
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Default Re: Onan Quiet Diesel questions
Mine will act that way when the fuel filter needs changed. I change my fuel filter about every 250 hrs and oil at 100 hrs. Have you changed the air filter? Mine get dirty pretty fast as my unit is mounted in the belly box on my toter when you are parked on the dirt there is quite a bit of dust generated by the cooling fan.
It has gotten a complete service. Fuel ,Oil and Air filters, new lift pump, new thermostat, Injectors rebuilt.
The filter is cheap enough it might be worth changing again.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
