Liked 271 Times in 107 Posts
Yes or No?
Liked 167 Times in 81 Posts
I always used anti seize with non taper seat plugs. They make a crayon like anti seize that I used to put a couple of swipes on the threads, when installing on aluminum heads.
Tim Schmackpfeffer 762 SS |
Chevy LS so yes alum heads. I did not install the plugs that were in this car, so I don't know if anti seize was used,or if they were over torqued. I had to use a 1/2 breakover to pop them loose.and I dont want to go through that again.
Liked 482 Times in 159 Posts
You must suspect that anti-seize was not used when you posted. I do not have the experience that you do, however I was taught that dissimilar metals should use anti-seize. 1/2 breaker , wow my father always told me not to go crazy, "they are only plugs not head bolts" LOL.
Liked 285 Times in 87 Posts
Yes, in aluminum.
Liked 920 Times in 259 Posts
Sparingly, just like the elbow grease used to tighten them.
#8 | |
Liked 706 Times in 283 Posts
I understand the anti seize because of 2 different metals, but I thought that it enhanced poor grounding of plug to head. Maybe I dreamed it.
