Old 08-23-2020, 01:52 PM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default Holley side hung float
Do holley carbs with side hung floats need jet extensions in the rear? If so is a notched float needed as with center hung floats. This would be on a single carb installation.
Jim Hawkins is offline   Reply With Quote
Old 08-23-2020, 03:06 PM   #2
Ralph A Powell
Liked 225 Times in 136 Posts
Default Re: Holley side hung float
If the carb I mounted primary bowl in front and secondary rear it won’t hurt. At one time Holley made jet ext that fit inside the jet they were about 1 inch long. They were made originally for the GT-40s at LeMans when Ford ran the 427 with a single 4V. Those were with what they called the LeMans float bowls. If you check at one time Holley made the nitro black floats for the side hung bowls I think the oe floats were brass. You can not notch those floats.
Old 08-23-2020, 03:08 PM   #3
pmrphil
Liked 348 Times in 152 Posts
If it leaves hard enough to uncover the jets, then yes, it's needed. And, yes, Quick Fuel sells a notched, thinned, float just like that. I always keep one in stock.
Phil Molski
PMR Performance
S/C 1623
