Liked 10,793 Times in 2,244 Posts
In the A B C six pack car we got over 15 years of service from a pro gear Dana. 3700# in C to 3200# in A
Liked 225 Times in 136 Posts
Do you guys use the a spreader to get the ring gear out and have preload?
Liked 274 Times in 143 Posts
Herb McCandless told me to avoid the spreader unless absolutely necessary. If you're not careful with it, it will bend the housing. A box end wrench on the ring gear bolt, and carefully turning the yoke with push the carrier right out of the housing with little to no effort.
Liked 1,943 Times in 584 Posts
I don't use the spreader. I have just enough preload where it takes a couple of taps with a plastic mallet to get the spool into the housing. I dont run much preload on the pinion either. Doing it this way there is little to no drag. I have been getting great gear life well over 1000 runs. Running either 6.17 or 5.86 ratios depending on the engine combo.
Mike Pearson 2485 SS |
Thanks to everyone for their help =
We are back together and ready for Vegas Natl's!
