Old 09-12-2020, 01:07 PM   #1
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
Default Broken Front Wheel Studs
I have had a problem with front wheel studs breaking on my Fairmont. I have found 6 of them broken all the same way. I say found because they never break at the track, I find them on the shop floor after a race, usually 1 to 2 weeks after parking the car. They literally pop off the hub.
First time I suspected I had over torqued the lug nut, replaced the broken stud and torqued all the 1/2 lug nuts to the recommended torque 85-95, I use 85.
Previously I had used an insert on the wheel with a 12 point nut (See picture). After talking with Weld they recommended that I change to a shouldered lug nut which I did. Nothing changed, still breaking studs, sometimes the same one twice. The lug nuts are not bottoming out on the hub when tightened.
The hubs are Aerospace, studs are Moser. Lug nuts are from Weld.
I'm getting frustrated as I don't want this to happen going down the track!
Kelly Lane Stk 4991
Name:	Wheel Stud (11).JPG
ID:	55708   Click image for larger version
Name:	Wheel Stud (10).JPG
ID:	55709   Click image for larger version
Name:	Wheel Stud (8).JPG
Name:	Wheel Stud (4).JPG
ID:	55711   Click image for larger version
Name:	Wheel Stud (5).JPG
Shadylane is offline   Reply With Quote
Old 09-12-2020, 02:02 PM   #2
SSDiv6
Default Re: Broken Front Wheel Studs
Kelly Lane Stk 4991
From the pictures, it appears you have a very long stud and you may be stretching the stud beyond its yield point. Inferior fasteners will shear as shown in the picture when they are torqued beyond their yield. Therefore, I suggest you go with a shorter stud from either ARP, Mark Williams or Strange Engineering and shorter lug nuts. Also, looking at the cross section of the sheared stud, it appears to show inclusions, typical to inferior material or they may have been improperly heat or solution treated.
Old 09-12-2020, 02:24 PM   #3
MR DERBY CITY
Liked 8,098 Times in 1,531 Posts
Just curious, do the studs thread into the hub OR are they a pressed fit ? I am not a big fan of Aerospace , but I have a hard time placing any blame on them. ARP is a pretty good suggestion. Absolutely nothing wrong with using the sleeve and 12 point nut..... what is the weight of the car ? I would go buy a few LOTTERY tix, you are very fortunate this didn’t happen while going down the track....
Old 09-12-2020, 02:41 PM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Make sure the stud doesn't have a slight chamfer where it transitions to the hex portion. Mine did...a slight chamfer on the hub was needed.
"That'll never work....."
Old 09-12-2020, 03:42 PM   #5
pmrphil
Liked 348 Times in 152 Posts
I used to bend/break studs on my dragster just like that, changed to Mark Williams studs and problem was gone.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 09-12-2020, 04:54 PM   #6
CMcAllister
Liked 920 Times in 259 Posts
Those thick Draglites typically use a 3" stud. 2" is too short.
I would definitely go to a Strange, ARP, Moroso maybe, stud. That broken stud looks awful. Just failed.
For what it's worth, right or wrong, I don't pull the front nuts that tight, especially on those 3 piece wheels. Light cars I'll go to 50. Doesn't distort or damage wheels. Never had one come loose.
Old 09-12-2020, 06:23 PM   #7
Shadylane
Shadylane's Avatar
“Just curious, do the studs thread into the hub OR are they a pressed fit ?”
Screwed in.
Car weighs 3030
Kelly Lane Stk4991
Old 09-12-2020, 06:26 PM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Screwed in.
I have the same hubs on my car. They are 1/2 inch thread in studs. I have never broken any on my car. I think he has been over torque them. I don’t put that much torque on my 5/8 rear studs.
Mike Pearson 2485 SS
Old 09-12-2020, 07:32 PM   #9
CMcAllister
Those things should actually be fine at 85. Unless they are junk. We pull most OEM street cars to 100 and they aren't 1/2".
When's the last time you checked your torque wrench?
Do you check torque between races? Do they loosen up, like the stud has stretched?
Old 09-12-2020, 07:37 PM   #10
Kirk Morgan
Liked 81 Times in 45 Posts
Iam wondering if the inner diameter of the wheel is interfering with the outer diameter of the hub causing a wedge effect.Can you unscrew the broken studs out of the nuts without much effort? If they wont i would think there is some kind of a wedge affect going on..
Kirk Morgan is offline   Reply With Quote
