Liked 11,017 Times in 2,265 Posts
Is the mounting surface level on intake side to side?
Liked 227 Times in 138 Posts
Change both gaskets float bowl side and main body side also replace the the 4 bowl screw gaskets and torque the the bowl screws to 35 in-pounds and your problem should go away.
Liked 2 Times in 2 Posts
power valve hitting the base plate screw "boss" in the vac. chamber not allowing the m/block gasket to seal to the venturi surface. this is a common problem with "older" venturi's. check a new venturi an you'll see what i mean..
this is also made worse if you are using the new non-compressible p/valve gasket with a mill'd surface of the venturi as they become closer together. |
Liked 66 Times in 37 Posts
o ring on needle and seat
72 cutlass |
