Old 09-26-2020, 03:59 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 350/360/330 SBC with Edelbrock heads
Is an aftermarket intake legal?
Larry Woodfin 471W
Old 09-26-2020, 04:20 PM   #2
rdlong1961
rdlong1961's Avatar
Liked 5 Times in 1 Post
Default Re: 350/360/330 SBC with Edelbrock heads
Casting No's10185024 ,3972110, and 3972116 Aluminum
Rodney Long - #3488 Stock
rdlong1961 is offline   Reply With Quote
Old 09-26-2020, 11:15 PM   #3
Dragsinger
A quick scan shows finding the correct intake will be a challenge. Anybody have one?
Larry Woodfin 471W
Old 09-27-2020, 06:43 AM   #4
rdlong1961
rdlong1961's Avatar
pm sent
Old 09-27-2020, 08:50 AM   #5
Dragsinger
Rodney, Thanks, I will follow up.
Larry Woodfin 471W
Old 09-27-2020, 08:58 PM   #6
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Larry, we have used all 3 intakes for this combo. The 110 is expensive and hard to find (for a SBC part), and they all 3 perform the same from what I’ve seen. I have an 024 on one motor and a 110 on the other right now. There was a 116 or 024 on eBay a while back, if I remember right it may have been Steve Ficcaci that had it listed.
3207 D/SA, C/ED
Andrew Hill is online now   Reply With Quote
Old 09-27-2020, 09:42 PM   #7
Dragsinger
Andrew,
do you run the iron or aluminum heads? What class and what performance are you achieving.
Larry Woodfin 471W
Old 09-27-2020, 09:54 PM   #8
Andrew Hill
Originally Posted by Dragsinger View Post
Andrew,
I run the factory iron heads, the aluminum heads are so much bigger than the factory runner volumes that it would take a lot of work to get them to the allowable levels. I’m not familiar with anyone running them on a SBC in stock yet (but maybe somebody has that I don’t know of).
I run D/SA and have run as quick as 10.23 at 127, which was at Indy last year. If you’re interested in a second gen Camaro, I think there are a lot of good options. The lower compression 71-72 Z28 combo is good as well, and I think the 73 Z28 with the Quadrajet has a ton of potential, as it’s only rated at 294.
3207 D/SA, C/ED
Old 09-27-2020, 10:09 PM   #9
Dragsinger
Andrew,
I have a 1970 Camaro Z28 spotted that is in good condition. It is all original. What does it take to convert a 70 model to 71 or 72 or 73?
Larry Woodfin 471W
Old 09-27-2020, 10:22 PM   #10
Andrew Hill
Andrew,
I believe the only major difference is the grille, which is different between the 70-71 and the 72-73.
3207 D/SA, C/ED
