Liked 239 Times in 114 Posts
On a PG low gear is just the band on . Reverse is just the Reverse clutch on . The transbrake on , is just the band on and the reverse clutch on . Your brake does not work and you have no reverse . I think possibly your Reverse clutch circuit has a big leak in it . That could be reverse piston seals are leaking or possibly the reverse clutch pack has too much clearance and physically can't clamp the clutch plates ,
Liked 231 Times in 69 Posts
Talked to my tranny guy. He said it has a BTE universal input shaft that works with both the 2.08 set and the 1.76 set. He did mention to make sure the plunger is actually traveling the correct distance in the valve body. He said I would have to remove the pan, push the solenoid button manually and watch to see if the plunger is covering the channel completely. He did also mention the plate behind the tail shaft housing. There is supposed to be an aluminum/billet plate installed. If that plate is not there, you won't have reverse. I removed the transmission last night, and will be bringing it to him this weekend. Sure is a whole lot of work just to TRY a power glide in the car. I keep breaking the 400, so I'm finally trying some advise from the local racers and trying a power glide. But I am getting pretty proficient at removing and installing transmissions in the car. All for the love of racing.
#4 | |
Liked 497 Times in 243 Posts
And why take the 2.08 out and go with 1.76? How much does car weigh? How much H.P.? Inquiring minds would like to know... |
Car weighs 3700 with 200 lbs driver, estimated 650 horse, 10.30's @ 128 mph, 1.35-1.38 60ft with 2.74 1st gear with turbo 400. I was always told a 400 is stronger than a glide, but a lot of local racers have switched to power glides. They talked me into trying one, so I borrowed one from a friend that came out of a super stocker. Brought it back to the local tranny guy today. He installed a plate behind the tail shaft housing to cover the cresent channel. He Said that should fix the reverse issue. Brought it home, installed it back in the car. Still no reverse, and trans brake does not hold when activated in 1st gear.
We did verify that the trans brake plunger was moving far enough to block the channel. He also pressurized the system with air, which applied the band, then manually pushed the trans brake solenoid, and turned the input shaft, to verify 1st gear was working on the out put shaft. Not sure if I got all that correct, but that's why I bring it to a transmission guy. Sure is frustrating, had this tranny in and out 3 times this week.
He removed the 2.08 and replaced it with the 1.76 because he thought the 2.08 was too weak for my heavy high torque car. He was worried about me breaking the 2.08 set.
