Old 10-30-2020, 06:19 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default 200 metric issue
Ok, I figured since I am a master GM tech i would try my hand at checking why my metric lost 2nd gear. It had a high gear flare as well which could have been the eshift. Going manual valve body because the other wasn't legal but it was in it when i got it. Now, definitely steel metal in pan verified by a magnet. 3rd(direct) clutches are burnt but everything else looks ok. Also only 4 frictions in forward clutch, 2 in reverse. Band looked ok and billet pin isnt broken
jamie2370 is offline   Reply With Quote
Old 10-30-2020, 06:20 PM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: 200 metric issue
How's the sprag?
"That'll never work....."
Old 10-30-2020, 06:36 PM   #3
jamie2370
Alan, its fine. Spins one way, doesn't the other. I think converter may be trash too. Not really finding anything steel in trans damaged. Drum(not aluminum)has been banged pretty good(the 4 tangs) by a previous sunshell but the current shell looks new.
Old 10-30-2020, 09:47 PM   #4
Jamie, What kind of servo? How much band clearance?
I would say, if the direct drum and the band is not burned, and everything else is intact, then the band is not applying.So now you've got to check the circuitry and fluid to the servo. I see the 3rd gear deal as a separate issue. We'll deal with that later.
Who built this unit? You're putting a TA valve body back in it?
*** Is the band anchor pin intact? Not sheared off?
Old 10-31-2020, 05:40 PM   #5
jamie2370
I did not measure anything before I unstacked it. Assumed with steel in the pan it was gonna be bad. Anchor pin is good. Going with a Sepanek manual valve body. Its going to my trans guy now. Next question. Should you have to put 3 washers(stacked together) between the converter and flexplate? Thats how it was when I got it. I'm guessing mabye 1/8" worth of shim. I feel it is really close to being bottomed out in pump.
Old 10-31-2020, 06:01 PM   #6
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Jamie,
1/8 inch sounds like the thickness of a motor plate. Did you try removing the washers and checking for converter hub engagement?
Lew Silverman #2070
"The Wagon Master" N/SA
Old 11-01-2020, 09:26 AM   #7
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
What's the distance between convertor and flexplate with shims and convertor bolts not tightened ?
Old 11-05-2020, 10:37 AM   #8
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
with the converter unbolted and pushed into the trans until it is bottomed out, you need 1/8 inch (.125) space between converter mounts and flexplate. In other words, converter mounted up needs 1/8 (.125) from being bottomed out in the trans.
Mike Moller
NHRA 203 Q-R-T/SA
Old 11-05-2020, 01:04 PM   #9
Glenn Briglio
Low volume pumps sometimes require less than .125
Old 11-05-2020, 09:18 PM   #10
Greg Barsamian
Liked 427 Times in 97 Posts
Call the other "Fast Jack" Sepanek....... He will instruct you as to how much to shim the converter
