Old 11-02-2020, 12:05 PM   #1
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Default Re: Motorwheel flies on 5/8 studs
Hello Stewart;
I have done this as I run the "Fly's" on my car.
These are the three ways I did it starting from easiest/cheapest to hardest/expensive.
1) Go to a hobby store and pick up a 3' piece of brass tubing that is .750 O.D. and .6875 I.D. Cut it to desired length. The part number I have for it is K+S9225. Really easy and works great. $20.00.
2) Get some stainless,same O.D. .625 I.D. Machine it to .6875. Cut to length. This was painful.
3) Have the wheels bushed at a machine shop to fit the M/W studs. I did this with a set that the holes were no longer round. Works well but it cost me $300.00.
Allan
55 Chevy is offline   Reply With Quote
Old 11-02-2020, 04:58 PM   #2
Stewart Way
Liked 70 Times in 22 Posts
I have access to a lathe so I guess I will make some spacers. Just didn't want to miss out if someone had a solution that was just a slip/press on. Thanks
Stewart Way 2424 SS
Old 11-02-2020, 07:53 PM   #3
NHRA3106
Liked 147 Times in 38 Posts
If you have access to a lathe, the easiest thing to prob do is to take the 5/8 aluminum wheel spacers and neck down to fit hole, and step back just shy of the thickness of the wheel. Double as a locator/spacer...just my thoughts.
Kevin
NHRA3106 is offline   Reply With Quote
Old 11-04-2020, 09:52 PM   #4
Stewart Way
I do have extra spacers so that sound like a a good idea.
Stewart Way 2424 SS
