Old 11-14-2020, 11:29 AM   #1
Dirk Olson
Liked 172 Times in 46 Posts
Default Re: Camaro steering box
I contacted Bob Blackwell about changing my box out to a Vega style box and was told not legal in Stock per Wesley.
Dirk
A/S 5036
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 11-15-2020, 02:07 PM   #2
t.tosto
Liked 62 Times in 23 Posts
You can rebuild these boxes easily, Midwest Directional Services offers a rebuild kit #RK550, 816 796 6400. It consists of brg. races, bsg. and seal, no special tools needed. Make sure worm and sector gears not worn.
t.tosto is offline   Reply With Quote
Old 11-15-2020, 08:47 PM   #3
SSDiv6
One of the best in the country is Redhead Steering in Seattle, Washington.
They rebuild and improve old steering boxes and make them better than new.
https://redheadsteeringgears.com/
Old 11-16-2020, 02:46 PM   #4
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I recently found a brand new (NOT remanufactured) box for my '66 Nova, made by a company called Lares Mfg in Minnesota. They're sold through Rock Auto...I just now looked up 1967 Camaro and they make them for those, also. I opted for the fast-ratio 16:1 manual box. Haven't installed it yet, so I don't have any feedback on how well it works, but it's got to be better than the 54-year old original. Oh, and they're very reasonably priced too! Around $250.
Paul Merolla is offline   Reply With Quote
Old 11-20-2020, 03:16 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
,Larry & FED gave me these a while back.. hope it helps
Adger
you have several choices.
* S-10 manual box [with the S-10 box in most cases it is a direct replacement. Input spline & pitman spline same as OE. It will have a four bolt top]
* manual GM box from 70's cars [this is also a direct fit in some cases. GM produced several spline counts so it takes some comparing to find the exact match. This is a three bolt top. This box is about one pound lighter than the S-10 box and overall slightly smaller.
* Vega box [this box is smaller and lighter than both the above, however, it requires a custom/special pitman arm. Ed Quay, Flaming River, and maybe others furnish the special arm.
Of the three, I would look for the 70's box.
Larry Woodfin, GT Super 10
Adger, I "think" all GM manual boxes will be about the same in ratio. [maybe an exception but it would be a rare option] The greater turn to turn ratio of manual boxes is an advantage, steering is not touchy]
The 60's and 70's three-bolt top gear is a good choice but it takes careful searching to find the correct spline count. They are out there, I have found and installed several.
An S-10 box is available reman from most parts stores. To my knowledge, there is only one part number. It's advantage, a direct bolt in replacement, remove power gear, install S-10 manual gear.
The quicker ratios come with PS boxes.
471W
Posts: 2,786 Re: 3rd Gen F Body Steering box
________________________________________
I have a Chevy book (from GM ) 1984 that lists 2 Manual steering gear assemblies
7806396-------20:1 ratio---- 67-75 Camaro
7819935-------16:1 ratio---- Monza and Vega
FED 387
Adger Smith (Former SS)
Old 11-20-2020, 09:56 AM   #6
Signman
Liked 269 Times in 99 Posts
If you fell the wheel stand is the issue install a damper. It is a safety item and should be allowed based on that alone.
Old 11-20-2020, 11:51 AM   #7
SSDiv6
Many already run a damper and Ed Quay even sells a kit to install the steering damper.
