Old 11-11-2020, 06:48 PM   #1
Randy Wells
Liked 1,144 Times in 354 Posts
Default strange Master Cylinder
I am doing some upgrades on my 1980 I/S Camaro. I put strange brakes all around, install was clean nice brakes. Now I am replacing the factory master cylinder with the Strange unit. I am scratching my head now, I pulled the factory one off, 2, 3/8 studs through the firewall, the Strange unit has 1/4" holes and they do not line up good with the 3/8 studs. Looks like I will need to drill out the master cylinder base to 3/8,. Can someone who has converted one of these over offer me some advice.
Thanks
Randy Wells
I/S 5628
Randy Wells is offline   Reply With Quote
Old 11-11-2020, 07:16 PM   #2
MR DERBY CITY
Liked 8,114 Times in 1,531 Posts
Default Re: strange Master Cylinder
Thanks
Randy Wells
I/S 5628
An aluminum adapter plate is in order,..... call Strange....
MR DERBY CITY is online now   Reply With Quote
Old 11-11-2020, 07:43 PM   #3
bykr
Liked 167 Times in 81 Posts
That's Strange (no pun intended) every one I've got from them has .328" holes. Like this one B3359TA
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 11-11-2020, 07:51 PM   #4
Randy Wells
Originally Posted by bykr View Post
That's Strange (no pun intended) every one I've got from them has 3/8" holes.
The holes on this one are chamfered on the firewall side that seems strange, maybe so you can drill them out if needed.
Old 11-11-2020, 08:08 PM   #5
Randy Wells
That's Strange (no pun intended) every one I've got from them has 3/8" holes. Like this one B3359TA
Mine is a B3359, just measured the holes, .312 or 5/16 was guessing at 1/4". This is the one Strange said I needed. I think I will be ok drilling them out to3/8.
Old 11-11-2020, 08:42 PM   #6
jimmyparker
Liked 309 Times in 88 Posts
I don't drill them out, I use a rattail file and work to fit, the 3/8" drill bit takes out material in the wrong places along with widening the holes.
jimmyparker is offline   Reply With Quote
Old 11-14-2020, 01:36 PM   #7
J&S Racing
Liked 327 Times in 87 Posts
This is the adapter from TRZ Motorsports I used for my 69 Camaro. Fwiw the Bickle brake rod retainer works with it.
Old 11-14-2020, 01:41 PM   #8
J&S Racing
Old 11-14-2020, 01:44 PM   #9
J&S Racing
Old 11-14-2020, 02:11 PM   #10
MR DERBY CITY
And we have a winner........
