Old 12-03-2020, 08:47 PM   #1
Ralph A Powell
Liked 225 Times in 136 Posts
Default Re: General Cylinder Head Flow Numbers discussion
You want a port that continues to flow well past your max lift point and not go turbulent and is quite on the bench!
Old 12-04-2020, 03:43 PM   #2
HawkBrosMav
Liked 302 Times in 73 Posts
Ralph not being in the room when the heads are being flowed and not owning my own stuff to do it... is there a way to know if the port is quiet by looking at CSA and port velocity? Do I just need to ask the head guy if they were quiet?
How far past max lift would you like to see it "flow well" .050?.0100? more? and by "flow well past" do you mean the CFM should still be increasing or just not backing up a lot? if it just holds the peak CFM from say .350-.500 at a fairly constant CFM but isn't gaining anything or dropping off at all is that okay?
Thanks
Brad
Old 12-04-2020, 03:53 PM   #3
SSDiv6
Liked 1,604 Times in 583 Posts
Thanks
Brad
Brad,
It needs to be on the flow bench and the quietness is the sound of the air. Usually test 0.100" ~ 0.150" past your required maximum lift and don't worry about the behavior past that limit.
Old 12-04-2020, 04:56 PM   #4
Dissident
Liked 73 Times in 36 Posts
Folks interested in flow bench testing:
These days I can't hear worth a dip, but I do know a fair amount about flow bench testing and there are multiple ways to discern the stability of airflow in the cylinder head or manifold without hearing....
The cylinder head should be tested with the manifold and carb/throttle body attached so the "real" flow test is indicative of what the system is doing. That kind of testing is a bit more difficult, but much more meaningful. From that flow data, potential power can be predicted as can the rpm at which peak power will occur. Measuring a load of intake manifolds is worth the effort. Unless one follows the outline that I posted previously. You might find some worthwhile tips in HPBooks, Engine Airflow
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 12-04-2020, 05:33 PM   #5
Billy Nees
You guys might want to take a look at the "odd" little rule change that's in the 2020 to 2021 rule changes. It just might have been put in there for a reason.
Billy Nees 1188 STK, SS
Old 12-04-2020, 06:22 PM   #6
SSDiv6
Saw that...inconspicuously and discreetly placed...
SECTION 11A: STOCK CARS: 1, BLUEPRINTING (Page 2) (12/3/2020)
Permitted per NHRA Specifications available from NHRA Technical Services
Department headquarters. Stock factory OEM Components (unless otherwise
specified) must be retained and remain unaltered (i.e., cylinder heads,
connecting rods, pushrods, crankshaft, etc.).
Clear as mud especially when aftermarket cylinder heads are allowed.
Old 12-04-2020, 06:57 PM   #7
HawkBrosMav
I guess I don't how that wording changes anything with the way the rules were written before... It already spells out what can be done and what can't be done as far as "alterations" so that would fall into "unless otherwise specified" meaning that all the heads that passes last year will pass this year just the same..
