Old 12-07-2020, 10:17 AM   #51
bert powell
Liked 34 Times in 12 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
I had a brake hose do this years ago. A piece of the rubber inside line broke loose and when you pushed the brakes it flipped over and blocked from releasing fluid, just line a line lock but would eventually bleed off. Easy check, push brakes and release, then try and spin the wheel by hand.
bert powell is online now   Reply With Quote
Old 12-07-2020, 10:55 AM   #52
gmeyer
Liked 35 Times in 16 Posts
Originally Posted by Henrys Toy View Post
We took the coil and ignition box out of the car and ran it on the Dyno made good power
Over the course of time the two things that would kill my car was a bad MSD box or a broken converter!
I had a Sprague break in my old Trans Torque converter , that I sent to Mike Munsinger at the time and he said the converter was good - put it in the car - still slow.
I finally sent the converter to Coan , they found a broken sprague , fixed it
Result - car fast again! These bloody things will really make you chase your tail.
Try a converter from a friend ,hopefully a known good piece, I think you might just find the "cure".
This is my thought it could be!
gmeyer is offline   Reply With Quote
Old 12-07-2020, 01:53 PM   #53
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
If you have lightweight brakes on the car and have been heavy on the brake pedal the pads can be worn on an angle and they will drag like crazy. Pull the pads off and measure them. If they are worn on an skew get some new ones.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 12-09-2020, 08:52 PM   #54
monte8616
Liked 14 Times in 6 Posts
Originally Posted by Greg Hill View Post
Is this a Quadrajet motor or Holley? If it’s a q-jet I would bet money it’s in the fuel system.
It’s critical to have enough fuel volume and a q-jet on a 454 SS motor would really stress your fuel system. A good pump like a Magnafuel, a #10 line from the cell to the regulator, appropriate return line, and a # 8 line from the regulator to the carb would ne required. Even if it’s a Holley I would do the same thing.
Have that setup!! Thanks!
monte8616 is offline   Reply With Quote
Old 12-09-2020, 08:54 PM   #55
monte8616
Thank you! You’re absolutely right and although I had the converter cut open and looked at but I know people who said they didn’t take the sprague apart - probably worth shipping it again!!
Old 12-09-2020, 09:59 PM   #56
voltdr
Liked 100 Times in 51 Posts
Back in the day, when I ran a sprag in my converters, when it broke, the ET really fell off but the MPH didn't fall off as much.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 12-09-2020, 10:42 PM   #57
It's not the converter.
Also, it seems to me, a choked down brake hose would be noticeable when driving through the pits or coasting into the staging lanes.
Old 12-09-2020, 11:18 PM   #58
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
I got a good friend with a 1969 Camaro that had the original rubber brake hose from the hard line on the chassis to the block on the rear end collapse sporadically internally. It caused a similar problem. Did not lock up on him coasting through the pits. Just a cheap easy thing to change if it's old or rubber.
Old 12-09-2020, 11:25 PM   #59
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Originally Posted by Lee Jordan (3223) A/S View Post
Is the chassis still lose? Are all the wheels free, brakes bearings? What about the rear end? Could it be getting tight and slowing the car? Just something else to think about.
After years of working around dragstrips I am still surprised at the number of cars that are hard to push. Sometimes a car might not start at the scales and has to be pushed out of the way. A racecar should roll easily. The best example of how easy a racecar should roll belongs to our old friend Al Provoast (RIP). Al could push that big heavy station wagon all by himself. While that may not be the issue in this case, everyone should make it a point throughout the year to see how easily your car can roll. If something is causing it to become harder to push by hand, rest assured it has nothing to do with how the engine is running.
Travis Miller is offline   Reply With Quote
Old 12-10-2020, 07:54 AM   #60
Liked 10,836 Times in 2,252 Posts
Dang Travis, that is one of my best kept “Speed Secrets”
