#51 |
Liked 34 Times in 12 Posts
I had a brake hose do this years ago. A piece of the rubber inside line broke loose and when you pushed the brakes it flipped over and blocked from releasing fluid, just line a line lock but would eventually bleed off. Easy check, push brakes and release, then try and spin the wheel by hand.
#52 | |
Liked 35 Times in 16 Posts
I had a Sprague break in my old Trans Torque converter , that I sent to Mike Munsinger at the time and he said the converter was good - put it in the car - still slow. I finally sent the converter to Coan , they found a broken sprague , fixed it Result - car fast again! These bloody things will really make you chase your tail. Try a converter from a friend ,hopefully a known good piece, I think you might just find the "cure". This is my thought it could be! |
#53 |
Liked 1,954 Times in 590 Posts
If you have lightweight brakes on the car and have been heavy on the brake pedal the pads can be worn on an angle and they will drag like crazy. Pull the pads off and measure them. If they are worn on an skew get some new ones.
Mike Pearson 2485 SS |
#54 | |
Liked 14 Times in 6 Posts
#55 | |
#56 |
Liked 100 Times in 51 Posts
Back in the day, when I ran a sprag in my converters, when it broke, the ET really fell off but the MPH didn't fall off as much.
Dan
Dan Foley SC 4698 |
#57 |
Liked 5,138 Times in 1,961 Posts
It's not the converter.
Also, it seems to me, a choked down brake hose would be noticeable when driving through the pits or coasting into the staging lanes.
#58 |
Liked 594 Times in 164 Posts
I got a good friend with a 1969 Camaro that had the original rubber brake hose from the hard line on the chassis to the block on the rear end collapse sporadically internally. It caused a similar problem. Did not lock up on him coasting through the pits. Just a cheap easy thing to change if it's old or rubber.
#59 |
Liked 276 Times in 27 Posts
After years of working around dragstrips I am still surprised at the number of cars that are hard to push. Sometimes a car might not start at the scales and has to be pushed out of the way. A racecar should roll easily. The best example of how easy a racecar should roll belongs to our old friend Al Provoast (RIP). Al could push that big heavy station wagon all by himself. While that may not be the issue in this case, everyone should make it a point throughout the year to see how easily your car can roll. If something is causing it to become harder to push by hand, rest assured it has nothing to do with how the engine is running.
#60 |
Liked 10,850 Times in 2,254 Posts
Dang Travis, that is one of my best kept “Speed Secrets”
