Prior to CalTracs, many were using Greg Luneack's Super Launcher Springs. They had lots of separation during launch.
Liked 805 Times in 341 Posts
It was a long time ago but when I first got my CalTracs I sent them a photo of my car and asked them if there was too much separation. They said there was and sent me another set of springs at no charge.
Liked 224 Times in 87 Posts
I run cal trac springs & his 9 way shocks on the back ( set on like 7 } , some of same combos in stock separate more & some less than my car . Looking at some pics of the races from this year alone . I might try to tighten up my rear shocks . And after 10 years of racing & trailing they may be done .
Liked 10,895 Times in 2,255 Posts
Can't stress enough using four wheel scales and video. Always try to go through the full range of what your trying but change one thing at a time.
Liked 2 Times in 1 Post
In no particular order:
1. Car’s never been scaled, but it’s nose-heavy… BB E-bodies are “born that way”, unless there’s some significant changes made to the weight distribution which I haven’t explored 2. I know there are better dampers available than the comparatively archaic Ranchos; it may require a DA more tailored to the application to improve times & consistency and I’ve been warned against bothering w/ some of the “shiny but wimpy” options that aren’t up to controlling the extension 3. I’m not sure I’d say the car’s. 60-fts got worse the faster it got… the data I posted doesn’t show how it had been getting chipped away as the car progressed from 11.0s (1.51-1.52) down to the 1.46x +/- range in the 10.5s 4. Also, the car’s fastest pass was a 10.52 at 126.44 w/ a 1.454, followed up by a slightly slower pass with a 1.452, so the car’s best 60s were on the best ETs & MPH passes, too 5. One of a number of changes that have been made and yet to be tested include switching from the shorter 20” (Super Stock” spring length) front segments back to the standard B/E body 22” 6. Am changing from 8” to 10” rims w/ the same 275/60R15 (~ 28” x 9”) radials, too, to help the footprint and -- hopefully -- make the tire a little less sensitive to tire pressure settings I appreciate all the input so far. - Brad |
Liked 226 Times in 137 Posts
I had Monroe double adjustable on my Modified car about 14 to 16 months I would have to have them rebuilt the trailer ride was very hard on them. I would just go down to Monroe and they would total rebuild them to good as new. There towards in the last 2 years if the trip was over 800 miles I would install a old set of rears for the ride.
