Liked 172 Times in 46 Posts
I believe that Kluber NBU 15 is a grease used for High speed spindles.
Dirk Olson 5036 STK |
Liked 354 Times in 120 Posts
There are seals that go in the axle tubes next to the carrier keeping lube out of the tubes. When you take off most of the lube ends up in the tubes. When running these seals you need less lube for the gears. Sealed bearings are meant to use there own lube and keep gear lube from making a mess of your brakes. Tom
Tom Meyer 5240 SS Stock ??? |
