Old 12-28-2020, 12:51 PM   #1
twg3724
Default Mass Weight of ProTrans?
Looking for some info on the total mass weight of a ProTrans in an effort to calculate weight savings against a TH400 (JW Bell Housing/ Alum Drums). Any input will be appreciated.
twg3724 is offline   Reply With Quote
Old 12-28-2020, 01:49 PM   #2
SSDiv6
Default Re: Mass Weight of ProTrans?
I believe the lowest mass racing transmission in the market may be the Coan Racing XLT line of transmissions which have a smaller diameter rotating assembly with billet components.
TCS Products in Canada makes a lot of the billet components that are used in the ProFlite transmissions.
http://www.tcsproducts.com/products/...-flight-parts/
Old 12-28-2020, 03:20 PM   #3
bert powell
Liked 34 Times in 12 Posts
Protrans 350 w SFI bellhousing and cast pan 110#
TH400 alum drums stock bellhousing 135#
Coan XLT with SFI bellhousing 115#
TH350 alum drums gundrilled SFI bell 125#
Weighed all of these except Coan, got info from racer who weighed it.
bert powell is offline   Reply With Quote
Old 12-28-2020, 04:19 PM   #4
twg3724
Awesome, Thanks guys!
Old 12-28-2020, 04:57 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
If you like I can weigh a gear set and a sun shell & all that rotates for the Pro flite.
I have one apart right now.
I can also make you a deal on my spare, almost any ratio you want.
Adger Smith
903 824 4924
Adger Smith (Former SS)
Old 12-28-2020, 10:05 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I will try and get the weight of a Kilgore Superlite .
Old 12-30-2020, 09:56 AM   #7
twg3724
sure more options the better.. Ive never looked too far into proflite or Kilgore. How do you like them?
Old 12-30-2020, 01:03 PM   #8
ss3011
ss3011's Avatar
I run a Kilgore in my GT/FA Formula with a BBC. I also run a Protrans in the SS/DA Coronet . Both are high quality transmissions . It would be neat if someone would build a SFI case for the TorqueFlite !
Old 12-30-2020, 03:04 PM   #9
340Cuda
Liked 805 Times in 341 Posts
Originally Posted by ss3011 View Post
I run a Kilgore in my GT/FA Formula with a BBC. I also run a Protrans in the SS/DA Cornet . Both are high quality transmissions . It would be neat if someone would build a SFI case for the TorqueFlite !
That would be cool. A while back I saw a project to do a 727 but nothing since. Never seen anything for a 904. I would love to no longer be a CSR customer.
Old 01-02-2021, 12:33 AM   #10
Chris Hill
Liked 244 Times in 26 Posts
For fun calculate the mass correction factor per gear.
Chris Hill
