Old 01-24-2021, 08:24 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Question Valve spring pressure
On a dual valve spring with the inner spring slightly shorter, when checking spring pressure with rimac tester, do you need to account for the inner lip from retainer. When spring is on head and closed, the inner spring is not at same level as outer. Valve spring tester is flat and contact with inner spring is about .060 lower. I know I'm rambling, but maybe someone understands my question. Thanks.
Ed McLawhorn Jr. is offline   Reply With Quote
Old 01-24-2021, 08:46 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Valve spring pressure
I use a .100" washer, a lot of retainers have a step about .100".
Paul Precht is online now   Reply With Quote
Old 01-24-2021, 08:51 PM   #3
Ed McLawhorn Jr.
Paul, I have used a washer and seen dad do same for years. I didn't know until recently how much difference it makes if you leave it out.
Old 01-24-2021, 09:00 PM   #4
BillK
Liked 30 Times in 17 Posts
Like the others said, you need to check it the same way that it will be installed. Same retainer and some type of shim to simulate the step in the head. What you really need to pay attention to in that setup is coil bind on the inner spring.
Bill Koustenis
BillK is offline   Reply With Quote
Old 01-25-2021, 02:57 AM   #5
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
I have used a quarter many times.
outlaw is offline   Reply With Quote
Old 01-25-2021, 07:09 AM   #6
SGSST109E
Liked 126 Times in 61 Posts
I always check mine using the retainer
SGSST109E is offline   Reply With Quote
Old 01-25-2021, 07:30 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I use the retainer right on the spring and just add the retainers thickness to the installed height on my Rimac tester. If there is a step at the bottom, add an appropriate washer that fits.
That’s the way it runs on the head and as was mentioned is a better way to see the actual pressure and check distance to coil bind
Rich Biebel
S/C 1479
Stock 147R
Old 01-25-2021, 10:31 PM   #8
Ed McLawhorn Jr.
Thanks guys. Always used the washer method, but nice to know about the retainer method when I lose the washer. lol.
Old 01-25-2021, 10:34 PM   #9
Adger Smith
Liked 880 Times in 311 Posts
I machine a shim or find a shim the same thickness as the retainer step/steps.
That way you are checking actual pressure and coil bind/coil bind clearance.
Adger Smith (Former SS)
Old 01-26-2021, 08:00 PM   #10
bubski
Liked 165 Times in 60 Posts
Bubski declares this post a winner !!
bubski is offline   Reply With Quote
