Old 02-17-2021, 08:51 PM   #4
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: Micro Polishing Crank ?
Originally Posted by bry-war View Post
Brings up a good point. With sufficient quality oil the parts do not touch anyway.....we hope. I have experience with an alky fc where we missed the tune and could “mash” a bearing .060” wider at the bottom of the bearing than its stock width measure at the parting line without blackening them. Hence the oil never gave up doing its job and working overtime. If anything,
polishing gives you justification of cost when it’s prettier. BTW: I don’t miss 60 and 70wt oil in my hair between rounds.
You are correct about the bearing journals; they operate on a hydrodynamic film of oil and should never touch.
The Micronite and Omicron surface finish helps the rough surfaces of the crankshaft, making them smoother and polished. The process consists of placing the part in a vibratory tumbler, with a specific media and run it for a specific amount of time. It also helps camshafts, lifters, connecting rods, valve retainers and valve springs.
