Old 02-23-2021, 10:34 AM   #1
AveryMcLawhorn
Liked 80 Times in 19 Posts
Default PCV vs EVac
Any suggestions for 283 SS motor. Trying to figure out which path to go.
AveryMcLawhorn is offline   Reply With Quote
Old 02-23-2021, 12:55 PM   #2
bykr
Liked 167 Times in 81 Posts
Default Re: PCV vs EVac
Evac. I don't see why you 'd want to put blowby into the intake.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 02-24-2021, 12:15 AM   #3
Crankcase vacuum.
Actually, you need both. One breather goes to back of carb. The other goes to a Y and to both collector probes.
Now you've got suction at all times, one way or the other.
If it really works good , you can turn the seals around on the crank ;-)
All you need then , is a crankcase vacuum port and a gauge. That gives you something else to look at in the lights :-)
Old 02-26-2021, 08:40 PM   #4
bykr
Crankcase vacuum.
So the increased crankcase vacuum ( better ring seal ?) offsets the intake charge dillution?
Old 02-26-2021, 09:48 PM   #5
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
For years I had a separator in the vacuum line between the carb and valve cover of my Cleveland. I've never had to drain any oil out of it.
Dave Noll, EF/S ,?/SA 6526
Old 02-26-2021, 10:12 PM   #6
It should anyway.
I'll take a controlled vacuum leak anyway I can, in a limited induction class...That goes for choke heat passages and hot idle compensators too ;-)
Old 03-02-2021, 09:41 PM   #7
e vassar
Liked 272 Times in 108 Posts
So when I had my carburetor car...I had a idea to create as many vacum leaks as possible, and jet up to compensate, the engine would run like it had a bigger carb. I was told NO...they will check for that.
Old 03-02-2021, 10:06 PM   #8
Yes, intentional vacuum leaks are illegal.
What I mentioned come from the factory that way... ;-)
