Liked 33 Times in 15 Posts
Anyone know the specs of the following cam? It's an older SBC Super Stock cam.
Comp Cams 4484/312-8 R6 Grind number R 7305 Comp was no help. Thanks in advance.
Joe Marcinowski 3377 STK Last edited by Joe Marcinowski; 03-18-2021 at 09:44 AM. |
Liked 734 Times in 385 Posts
Don't know what you are looking for. This is from an older Comp Cams Master List I have.
Stan |
Liked 348 Times in 152 Posts
Stan had the intake correct, high ratio, high RPM Super stock, using 1.8 - 2.0 rocker.
The 312-8 is a High torque .440 lobe, 312 adv., 284 @.050, 1.5 through 1.7 rocker ratio. And you probably know it was ground on a 106 lobe separation. Phil
Phil Molski PMR Performance S/C 1623 |
OK here is what is listed the exhaust lobe.
Stan |
Stan and Phil...thank you!
Any thoughts on a lash setting?
Joe Marcinowski 3377 STK Last edited by Joe Marcinowski; 03-18-2021 at 12:53 PM. |
#6 | |
No, I don't have any idea on lash settings. But remember lash will depend / change based on what rocker arm ratio you are using. Stan PS - I found this. It might be a good starting point Last edited by Stan Weiss; 03-18-2021 at 01:34 PM. |
Liked 237 Times in 126 Posts
I went through the Master Lobe Catalogue and came up with the same as Stan The side bar mentions .020. Try that. My 302 Ford with a Crane 448511 cam.254/262 with .599 lift lashes at .020 hot. Sounds like my stick is a lot like yours. Just Blue
Liked 132 Times in 52 Posts
What should lash change be when changing ratios? Say .020 with 1.6 then change to 1.7's what change in lash?
Terry |
Wallace Racing has a calculator for lash change with rocker change.
http://www.wallaceracing.com/calc-lash.php
