Old 03-23-2021, 07:47 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Smile G body suspension
Building a Malibu for stock . what bolt on rear suspension mods is everybody using. Any help appreciated . Mike
Mike Savelle is offline   Reply With Quote
Old 03-23-2021, 10:22 AM   #2
Brian Fink
Liked 28 Times in 9 Posts
Default Re: G body suspension
I would start with a real good set of adjustable rear shocks and initially tighten the right one more than the left ( you will have to test to determine what settings work best ) . The rear sway bar is critical and will need to be adjustable as well ; the best I found was HRpartsNstuff (330) 947-2433 . Good luck with your project .
Brian Fink is offline   Reply With Quote
Old 03-23-2021, 05:28 PM   #3
Stock4106
Liked 10 Times in 4 Posts
A rear sway bar is the best investment you will make. I bolted on the Xtreme Anti-roll Bar from BMR Suspension and it removed all body twist from my car. However, it does add about 25 pounds.
Owen S. Birkett
Stock/Super Stock 4106
Stock4106 is offline   Reply With Quote
Old 03-25-2021, 09:08 AM   #4
e vassar
Liked 271 Times in 107 Posts
They are pretty simple and inexpensive. Basically adjustable upper trailing arms to adjust pinion angle. Box in the lowers for strength. Solid or poly urethane bushings. Adjustable shocks,and anti roll bar or airbag in pass side coil spring to control rollover. Some good products and info over at maliburacing com
Old 03-26-2021, 12:30 PM   #5
Jim Kaekel
Liked 535 Times in 110 Posts
Like Brian F. said above, the HR Parts 'n' Stuff anti-roll bar is great, and it's made from hollow chrome moly tubing and isn't very heavy. There are alot of nice upper and lower control arms out there from alot of companies.
Jim Kaekel 3836 STK
Old 03-26-2021, 08:02 PM   #6
Bob Shaw
Liked 318 Times in 62 Posts
Some of the aftermarket lower control arms will change the wheelbase a little. Be sure to check.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 03-27-2021, 01:09 AM   #7
Those are the ones I use ;-)
Old 03-27-2021, 09:22 AM   #8
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Stock boxed arms with bushings and comp engineering shocks with an anti roll bar are good to 10 s. Some use the HR arms instead of boxing and bushing the stockers. The HR Anti roll bar is the top of the food chain but lots of Buick guys use the old ATR bar. This is a stock mount style and works very good. Stock GN springs go low 9s.
http://www.aggressiveauto.com/proddetail.asp?prod=SU00
The more people I meet the more I like my dog
Kevin
SSGN is online now   Reply With Quote
Old 03-27-2021, 07:43 PM   #9
e vassar
I dont think the adjustable aftermarket lower trailing arm is legal for Stock, but I could be wrong I used the Spohn anti roll bar
