Liked 20 Times in 15 Posts
SBC angle plug heads. does the plug gap go towards the piston or the head?
thanks Rod in AZ |
Liked 205 Times in 93 Posts
towards the piston. keeps electrode away from the piston.
Liked 126 Times in 61 Posts
The reason is to keep the gap from closing if the piston were to hit the grd strap
Liked 132 Times in 27 Posts
Liked 8,104 Times in 1,531 Posts
If the plugs are indexed incorrectly, you will probably know after the first run down the track. That’s how I found out ......As usual , ROD BUTCHER is correct ......I always buy a ten pack of plugs....
Liked 186 Times in 55 Posts
If with 10 plug you can't get them index correctly, Moroso sells indexing washers.
Moroso 71910 - Moroso Spark Plug Indexing Washers. They have 4 different washers Bob |
Liked 24 Times in 13 Posts
Bob, the washers you have/use, are they the ones that are sort of hollow/concave?
What I mean is the ones I had were hard to "seat" ; I never really knew if my plugs were tight or not. Terry K |
#8 | |
When I use them I tighten the plug till tight. The one's that I use are not hollow. Bob |
two kinds of index washers avialable.... flat or tapered. flat for early heads and tapered units for taper seat style plugs...
