I wonder if the split mono can be run without the traction devices?
Liked 10,738 Times in 2,234 Posts
Greg Luneack’s Launcher springs will be a bolt in and they work very well. Greg’s company is Tri-City Competition. He is also a wealth of knowledge for Stock and SuperStock.
Liked 2,486 Times in 697 Posts
Yes = I have run Caltraks without his bars and they worked fine on 500 HP Duster
(Hot Rod Mag - Project Feather Duster). However, Gregg's "Super Launcher" springs work better on it. The Caltraks are lighter and the goal was to get the car street legal under 2,400 lbs.
Liked 51 Times in 30 Posts
the super stock springs are shorter you will have to change front hangers,
you can use super stock springs using your main leaf, common upgrade |
#6 | |
Liked 274 Times in 143 Posts
That being said, the original 002/003 springs will require a 2" longer front hanger due to the shorter segment. I had a pair of those on a '65 Coronet. Without the longer front hanger, I could still safely run a 28x10.5 MT on the car without rubbing. To get the proper geometry, you have to make a new hanger hole in the frame rail ahead of the original to correct rear hanger location. It was a bracket car, but a simple way to alter the wheelbase a bit. Mopar did sell an S/S spring for heavier cars that did not require the longer hangers. My personal opinion...Buy the Launchers. |
Liked 124 Times in 44 Posts
I just acquired an NOS set of 456 and 457 springs for my '64 Sport Fury. Will I need to replace the front hanger?
