Old 04-21-2021, 09:06 PM   #1
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Re: GM 12 Bolt - Racepak Drive Line Sensor Bracket
I was going to mount on the yoke but would had to remove
And machine a surface for the ring
I just mounted the ring on the Tran yoke and the pickup
Off the tail shaft web. Works good.
I running a metric 200 trans
David
Willyracer is offline   Reply With Quote
Old 04-22-2021, 12:56 AM   #2
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
I built a mount, drilled holes in the webing and mounted there. I still have template I can post tomorrow
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 04-22-2021, 04:59 AM   #3
J&S Racing
Liked 319 Times in 82 Posts
Old 04-22-2021, 02:21 PM   #4
bestephen
Originally Posted by J&S Racing View Post
I like how clean this looks, Is there a special welding procedure for welding to the cast iron casing?
bestephen is offline   Reply With Quote
Old 04-22-2021, 03:24 PM   #5
J&S Racing
That I can’t answer, I had Mark Markow do this for me. I will say the collar had to be machined down to fit the yoke.
Old 04-22-2021, 09:04 PM   #6
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Mark Williams sells a yoke but it's about 7/16" longer with the flange for the collar.
Old 04-23-2021, 06:39 AM   #7
SGSST109E
Liked 126 Times in 61 Posts
A mig welder or for that matter a stick welder. A housing welds easy. I have a yoke from strange the only negative it is longer so the driveshaft needs to be shorter.
SGSST109E is offline   Reply With Quote
Old 04-23-2021, 07:56 AM   #8
curtis reed
Liked 125 Times in 59 Posts
TIG it with Inconel 600 filler rod.
curtis reed is offline   Reply With Quote
Old 04-29-2021, 03:37 PM   #9
tavbfl
This is how I did it for my Autometer DL driveline speed sensor.
'69 Camaro 468ci Doug Nash 4+1 6.36@107 1/8
tavbfl is offline   Reply With Quote
Old 04-29-2021, 07:25 PM   #10
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Mine is done with the sensor on the front driveshaft yoke and a bracket off the driveshaft loop.
