Old 04-22-2021, 09:04 PM   #11
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Re: GM 12 Bolt - Racepak Drive Line Sensor Bracket
Mark Williams sells a yoke but it's about 7/16" longer with the flange for the collar.
Old 04-23-2021, 06:39 AM   #12
SGSST109E
Liked 126 Times in 61 Posts
A mig welder or for that matter a stick welder. A housing welds easy. I have a yoke from strange the only negative it is longer so the driveshaft needs to be shorter.
SGSST109E is offline   Reply With Quote
Old 04-23-2021, 07:56 AM   #13
curtis reed
Liked 125 Times in 59 Posts
Originally Posted by bestephen View Post
I like how clean this looks, Is there a special welding procedure for welding to the cast iron casing?
TIG it with Inconel 600 filler rod.
curtis reed is offline   Reply With Quote
Old 04-29-2021, 03:37 PM   #14
tavbfl
This is how I did it for my Autometer DL driveline speed sensor.
'69 Camaro 468ci Doug Nash 4+1 6.36@107 1/8
tavbfl is offline   Reply With Quote
Old 04-29-2021, 07:25 PM   #15
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Mine is done with the sensor on the front driveshaft yoke and a bracket off the driveshaft loop.
