Liked 5 Times in 4 Posts
I was wondering what everyone was using for a turbo 400 reverse pattern hands-free shifter.Did some searching but was curious with new options out. Its a S10 bracket racer ,currently has a Shiftnoid on a Prostick thats hit and miss working.
Liked 271 Times in 107 Posts
Would probably go with Turbo Action
Liked 13 Times in 9 Posts
I run a reverse pattern 400 with a quarter stick and Shifnoid setup. had a problem with 2-3 shift until I figured out the pressure on the rooster comb was to high, relieved some of the tension by adding a couple flat washers between valve body and detent roller spring assembly as solenoid couldn't overcome down pressure.
Liked 133 Times in 76 Posts
I had a Pro-Stick with the Shifnoid setup and struggled with it. It was shifting 1st to 3rd at times. I changed over to a Pro Ratchet with the Shifnoid setup and it worked flawlessly.
Liked 26 Times in 12 Posts
Turbo Action
Thanks for the help guys! I almost forgot I posted this haven't got around to racing yet this year. Lots of good suggestions
Liked 52 Times in 32 Posts
M&M with air shift.....pricey but worth it. You'll spend about as much for the PPP after all upgrades.
SC 707Y |
Liked 3,226 Times in 981 Posts
While my first choice would be Turbo Action I’ve been happy with the PPP that came in my car and Brad (think it’s just him and his Dad that operate Precision) was very helpful in sorting out the air shifting issue I had initially. My issue with the M&M is that it looks like a borderline patent infringement on the PPP.
For some reason I was thinking you had to move the shifter over then it went ahead and shifted into third on its own.
