Liked 10,963 Times in 2,260 Posts
Some new some used, Comp, Isky, Lunati,GK
$100 each |
Liked 2,516 Times in 701 Posts
Larry:
Can you E Mail me specs on cams The Brand and if new or used I will probably buy at least a few. Racer7411@yahoo.com
Liked 24 Times in 13 Posts
Might be a dumb question but are these solid lifter cams?
Jeff Dudgeon '66 Coronet #10771 - bracket puke "the Flying Brick" |
We ran these cams with shubecks or Hill lifters, only three set made, Jerry Newsom, Mine and the "Truck". lifters had .005 movement to satisfy the rule as written then. I still run the limited travel hyd.
John They are all .467/ .483 cams. we have a set of '70 rockers to change to .455 /.470 from the 71 numbers |
Another dumb question - how well would one of these cams work in a street car?
It might be a good "Dairy Queen" cam. I never drove anything on the street with one of these cams but for $100.00 how can you go wrong. the best thing about a used cam is it's broke in.
I would recommend dialing the cam it with a degree wheel and checking valve clearance at split overlap to make sure the piston is out of the way. |
Are the Isky cams new?
If so I will buy them if the are set up for Hyd. Lifters
I will look today
Isky brand new in the box has never been out been unwrapped
109* 1651 on the box. TCS, just a guess, it might stand for Tri-City Special. Number on the box 041560-4 109. When we ground cranks I removed the fuel pump lobe. |
I will buy the Isky
PM me you contact # Thank
