#21 |
Who are the go-to guys for engine machining, transmission building, etc?
#22 | |
Performance in Vista Cal. It is 1 Second ++ when we need it to be! Must run 727 as 904 will not bolt in without Illegal Adapter. Pro Trans in Waco Texas did the Transmission. We break a lot of very good 8 3/4 in that heavy a car. 73 Roadrunner @ 3800 Lbs
#23 |
Thanks for all the replies. John what rear gear do you run?
#24 |
Believe it or not: 4.56 Dana with 94 Cir Goodyear Radial
Shift @ 5900 to 6000 RPM Not a High RPM Combo! Gregg Luneauk does our Short Block Brad Van Lant does our heads
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 05-05-2021 at 02:15 AM. |
#25 |
Would a 383 block bored .060 over be legal.
#26 |
Liked 693 Times in 205 Posts
Yes, for a 383.
#27 |
Liked 2,750 Times in 971 Posts
You might want to think about a filled 400 block as well.
#28 |
Liked 98 Times in 31 Posts
#30 |
Liked 10,838 Times in 2,253 Posts
A dana 60 for the back. Before you machine or choose an engine combination look at ring availability. The 360 with the factory 4.00" bore will have a better selection of piston rings than the 4.340 bore of the 400. Dont forget to look at rod selection on the approved list and if they are available.
Just some thoughts. |
